Fusion Design, Validate & Document
Stuck on a workflow? Have a tricky question about a Fusion (formerly Fusion 360) feature? Share your project, tips and tricks, ask questions, and get advice from the community.
Ghosted body
2 REPLIES 2
Jaeger1787
160 Views, 2 Replies
Ghosted body
The door which should be seen in the centre of the wagon side below, is 'ghosted'.
I have checked the preference settings and all the visibility settings I can find, but can not manage to create the 'solid' image of the door.  Please advise:
Keith
File attached.
2 REPLIES 2
@Jaeger1787 Right-click on the root (Local Side V1) node and set the Opacity Control to 100%. Also, set the Opacity Control of the individual body under the Bodies group to 100%
If my reply was helpful, please click the "Accept as Solution" button. It helps others get the answer quickly! A "Like" is always welcomed.
Rushikesh Kadam
Senior QA Engineer
Quality Assurance
Autodesk, Inc.
Jaeger1787
in reply to: Jaeger1787
Excellent, Rushikesh.  The screen shot was particularly helpful - for example, it clarified the term 'root'.  Thanks very much for that quick solution.
Keith
Technology Administrators
