The door which should be seen in the centre of the wagon side below, is 'ghosted'.
I have checked the preference settings and all the visibility settings I can find, but can not manage to create the 'solid' image of the door. Please advise:
Keith
File attached.
Solved by Rushikesh.kadam. Go to Solution.
@Jaeger1787 Right-click on the root (Local Side V1) node and set the Opacity Control to 100%. Also, set the Opacity Control of the individual body under the Bodies group to 100%
If my reply was helpful, please click the "Accept as Solution" button. It helps others get the answer quickly! A "Like" is always welcomed.
Excellent, Rushikesh. The screen shot was particularly helpful - for example, it clarified the term 'root'. Thanks very much for that quick solution.
Keith
