Joints Vs. Mates
Joints Vs. Mates
mika.takalo
Joints Vs. Mates
mika.takalo
How can I joint my support to arc rolled square pipe? In a typical "mates", I would just make three different mates, lines against the bottom of the pipe and support end surface against the pipe another side.
TrippyLighting
Please share your design
mika.takalo
Never. Those files are my private property. I will make some plain example model which one I can share.
mika.takalo
http://a360.co/2hTyeY7
Joint that another support to that arc shaped square pipe. Tangentially and 250mm from that first support.
mika.takalo
Made it. I´m driving "joint origin" with sketch and turning the support angle on the right position.
