Message 1 of 10
can PCB step files create speed issues?
I've noticed that project files containing PCBs can get kind of slow when computing motion - like say if you try to drag-rotate a revolute joint.
A PCB (printed circuit board) in my case is typically a STEP file which may contain some 150 components which I then assemble into a Rigid Group. That group is then attached to the rest of the model with a single Rigid Joint. My STEP files are created with Altium Circuitmaker.
Is it possible that such entities slow computation?
If so, any tips? (Like is it possible to convert the many components of the PCB into a single Body, even if that's at the expense of having lots of nice colours?!)
