Joints not having effect - moving body does not move connected components
kierenj
Message 1 of 11
kierenj
My workflow so far:
1. Create a parametric dodecahedron using a great screencast I found here - end up with a regular dodecahedron body
2. Import 12 x components, one for each face
3. Create a sketch on each face using construction lines to find the midpoint
4. Create a ball joint to move and align each component to the midpoint of each face, pointing outwards
At this point, I can edit the original parameters and everything adjusts nicely.
However, I now want to split the dodecahedron and move/rotate one half around. If I do so - or even if I just move the whole dodecahedron body - the components are not "attached" / do not move with the body.
How can I achieve this please?
Replies (10)
Message 2 of 11
TrippyLighting
Please share your design (public link through data panel).
Message 3 of 11
kierenj
Link: https://a360.co/2PmPJiN
Thanks!
Message 4 of 11
g-andresen
the reason is: You tried to create joints between components (LED) and Body (dodecahedron)
1. Create a component from the body.
2. what should the ball joint be for?
joints are only possible with componentsjoints are only possible with components
günther
Message 5 of 11
kierenj
Ok, so if I convert the body to a component, then create the joints, it should work?
The ball joint was a convenient way of moving and orienting the LED components to the faces. I could also move and align, but I suspect they wouldn't then be pinned in place for subsequent transformations or operations on the dodecahedron?
Incidentally, you're right that I tried to create joints between a body and components.. but also that I succeeded to do so: the joints exist! Is this something that's not really supported, but it let me do it for some reason?
Either way, I'll give it a go, thanks very much
Message 6 of 11
lichtzeichenanlage
- Convert the body to a component
- Create holes where you can mount the LEDs. Alternatively you can create joint origins or sketch points to mount the LEDs.
Message 7 of 11
SaschaZimmer
Hi @kierenj
That's certainly not the desired effect. How did you see the attachment of the LEDs? The body does not contain any holes
Sascha Zimmer
Industriemechaniker CNC Bearbeitungszentrum
Opel Automobile GmbH
Facebook |LinkedIn
Message 8 of 11
kierenj
I've converted the body to a component, created another joint, and again, if I move the component, the connected component doesn't move.
I realise the body is solid with no holes currently - I'm looking to orient the LEDs, then use them to cut out an appropriate hole. That's not my question -
My question again is - how do I make it so that when I translate, or slice the main dodecahedron and translate pieces of it - the attached components move with it?
Please?
Message 9 of 11
g-andresen
You must also renew the joints so that the LEDs have a connection to the component and not to the body.
This way: right click joint > Edit joint  > delete C1/C2 > select new joint!
günther
Message 10 of 11
kierenj
Thanks, but I recreated them from scratch after converting to a component. Moving the shape component still doesn't move the connected ones
Message 11 of 11
SaschaZimmer
Hello @kierenj
Maybe you have to Fix The Main Component ?
I made a Screencast.
https://autode.sk/32XrLP1
Sascha Zimmer
Facebook |LinkedIn
