Joints from an STL? -- Mesh won't convert to or add to component
haleypearse
haleypearse
"Create component from bodies" just does nothing. Nor can I drag the mesh into a component. Is there a way to use joints on an imported STL? So far none of my STLs have worked.
lichtzeichenanlage
IMHO you only can assemble solids. If you want to import geometry from other CAD systems I would try STEP / STP files.
TrippyLighting
Correct, joints only work with solids. IF the meshes for the gears are not to high in number of polygons then they can be converted into BRep. However it will be a faceted solid, so Fusion cannot recognize the center of round holes, because there are only facetted holes.
