I'm trying to join a coil spring on which I've flattened the ends by using the boundary fill method (as shown here in the forum by "HughesTooling") to a cylindrical bore in a housing but am not able to get the joint origin to attach in the right orientation. - see screencast below.
I would have assumed that the on-the-fly joint origin would either:
1) be default oriented normal to the extrusion axis of the spring (its not)
or
2) allow me to change the orientation (Either I can't or can't figure out how to do this)
I've succeeded in this effort by putting a dedicated joint origin on the coils spring - the tool to do this allows me to reorient the joint origin after I placing it on the coil. However, I'd like to do it with the on-the-fly tools, but can't seem to figure out how to do that.
Am I missing something, or can this only be done via the dedicated origin tool? If the later is the case, I'll add this to the Idea Station as the current default makes no sense to me . . .
Thanks -
