Joint keeps undoing itself; editing w/o doing anything puts it back
Noah_Katz
Message 1 of 15
Noah_Katz
The blast gate keeps wandering away from its position.
Editing the joint w/o doing anything puts it back where it belongs.
What do I need to do to make it stay put?
Replies (14)
Message 2 of 15
TrippyLighting
That is difficult to say without being able to see how the rest of the assembly is joined.
Could you share your design ?
Message 3 of 15
Noah_Katz
I'd be happy to, but .f3d isn't available with file/export, even after I broke all of the links.
Message 4 of 15
TrippyLighting
You can share a link to your design, which will allow us to download it. This includes assemblies with linked components. However, keep in mingd that having to download a design with linked components is a bit of a PITA and results in a lot of clean up work, so limiting the amount of linked componets is nice 😉
To find the link, locate your design in the data panned and click on the little info button in the lower right corner of the design icon.
Then select "Show details on web"
In the upper right corner of the web site - your design on your A360 hub - you'll find a share button that allows you to copy a link that you can paste into your next post.
Message 5 of 15
Noah_Katz
Thanks for the instructions, good to know.
http://a360.co/2mQYggM
The joint is top blst gt-cyc2, 7th from the last.
fyi, when I saved it the part was properly positioned, but when I closed and reopened the file, it was not, which will hopefully be the case for you.
I would like to know how to save an .f3d file locally to have as backup.
Also, how do you delete old versions?
I save several times a day and it seems wasteful to burden the servers unnecessarily.
Message 6 of 15
Noah_Katz
Just noticed that another joint, ft blst gt-wye (4th one up from top blst gt-cyc2) is doing the same thing.
Message 7 of 15
TrippyLighting
I've not been able to download your file and noticed the same thing with another deign yesterday. I am wondering if there's a problem with the website 😕
Message 8 of 15
Noah_Katz
Are you referring to the joint misbehavior or file issues?
Message 9 of 15
TrippyLighting
File issues. Nothing to do with your design!
Message 10 of 15
Noah_Katz
OK, maybe it will be better tomorrow after a restful night 🙂
Message 11 of 15
Noah_Katz
Rest didn't help; the component is constantly moving out of place (to the same location if that matters)
Message 12 of 15
TrippyLighting
Well...you need to fix the 14 warning and one error message that Fusion 360 is displaying. Then we'll talk.
Message 13 of 15
Noah_Katz
That might help 🙂
Or perhaps not.
Half of those are from work I've done after the problem started, and besides, why would a simple rigid joint between two components be affected by problems with components neither of them have relationships with?
Message 14 of 15
Noah_Katz
I've cleaned up the timeline and the problem persists:
Well for some reason nothing happens when I select My Screencasts
Message 15 of 15
Noah_Katz
here it is
