Joint issues with sub-assembly joints in larger assemblies
I had a quick question about joints as well! In a sub-assembly, I have a slider joint which works perfectly, but in a larger assembly, the component jointed moves around freely. However, all the other joints work perfectly fine, including a different, identical slider joint. Do you have any idea on how to fix this joint so it works in the larger assembly?
I am having this issue with the motors specifically.
