Joint conflict in assembly with multiple occurances of component
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I am trying to build an assembly with components which repeat over and over again. I built the Components in their own designs and then inserted them into a new design which is the assembly. When joining the parts in the assembly Fusion shows an error for joints which should have no conflicts. While trying to figure out why this happens I built two designs which illustrate this and have joint errors, which I don't know how to deal with.
In one design the geometry fits together but the last joint creates an error. In the other design having multiple occurrences of the same component creates a conflict. Fusion seems to apply each individual joint to all repeating occurrences of the component. I have added two public links to these projects, I hope they work and allow you to see everything relevant. I am not so familiar with how the sharing function in fusion works. If this doesn't work I will create a screen cast and add it.
thank you in advance for any help or advice, I am stuck and a little frustrated at the moment.
-Markus
