Designing a airship/creating creases
Hi
I have been trying to design a 3D model of a rigid airship in Fusion.  I was able to make the general smooth cigar-shape of the balloon by using the scale tool on a sphere (see attached).
However, I have been unable to find a way to create the creases or lines on the balloon which all converges into a single point, the main difference in appearance between a Goodyear blimp and the Hindenburg.  I would appreciate any suggestions/tips on how to do this.
Thanks in advance!
jodom4
Hey timothy.goyal,
Are you trying to build the object out of flat panels? Fabric?
Jonathan Odom
Community Manager + Content Creator
Oregon, USA
Become an Autodesk Fusion Insider
I_Forge_KC
Use the loft command between a sketch with the ribs shown and a point (tangent mode).
K. Cornett
Generative Design Consultant / Trainer
Thank you very much for your help @I_Forge_KC.  I was able to use that technique to create the flat panels as I had wanted.
