Join two slanted pipes
Hi
I want to make something a ladder against a big heavy machine.
I have two pipes (cilinders) standing up and rotated on the X-axis for 15 degrees AND rotated on the Z-axis for 15 degrees.
The connecting  pipe or cilinder is horizontal and parallel x-axis, how can i join the items.
thanks
etfrench
One way would be to lay out the ladder on a flat plane with the legs rotated 15 degrees and the horizontal pipe connecting the legs.  Rotate the complete ladder 15 degrees on the Z axis.
ETFrench
etfrench
Here's a screencast that uses the Pipe command to create a ladder.  If you add dimensions, it will be easier to modify the design latter.
ETFrench
that is very clear, thanks a lot.
Ruud
