Sheet Size Drawing
Sheet Size Drawing
Sheet Size Drawing
Hi there
Just wondering if there will be an option to create custom drawing sheet sizes in the near future? Im sure its been asked but currently i have to scale down open in illustrator then re-scale re-save which is a bit rediculous. Is it also going to be available to start saving files as more than just the current csv/pdf im sure thats also been asked but again a lot of my suppliers require dxf's and do not use DWG's. Also how do I find out why fusion repeatedly crashes on me? Really enjoy the open forum platform for asking these sorts of questions but have just spent a large amount of time learning this program only to keep continually finding short falls I then have to try get around costing time/money?
Thanks!
Logan
innovatenate
Autodesk Support
Autodesk Support
I haven't seen any specific plans in the near term for custom size sheet. There's a roadmap for drawing over here. Check out the Mural for details on what the main points of focus are for the drawings area.
Below is a similar idea in the Ideastation it may help to add your support to by voting it up.
https://forums.autodesk.com/t5/fusion-360-ideastation-request-a/2d-drawings-custom-paper-size/idi-p/...
DXF export from Drawings is definitely something that is "On-Deck" or near term.
With regards to your crashing, I've seen only two error reports submitted by you to Autodesk in the last 30 days. Could you continue to submit these as they can be helfpul when trying to diagnose the problem.  I've seen a few posts where disabling the "Auto project edges on reference" in the Design panel of the Preferences helped with stability. Are there any consistent crashes that you can reproduce or is there a specific design that is causing more problems than others?
Nathan Chandler
Principal Specialist
