Item number not showing in the Parts List and Update Fusion 360 in order to view this data.
anil1973
anil1973
Hello
I am currently using Fusion 360 with manage extension. When opening some of the file I am getting the following warning.
Version: 2.0.12392
If I click ok. The files opens but when I go to create drawing the item numbers are missing from the parts list. When I view the file through the web fusion 360 portal the file opens, and the component view shows all item number.
I have cleared the chache file still I am getting the warning
I have also un-installed with the fusion 360 utility and did a fresh installed. Still getting the warning.
I have also deleted the fusion 360 and web service folder from the local app data folder still same problem.
I have done save as a new file, same issue.
Please can anyone help.
I am sorry I can’t share the files.
Many thanks for you help.
RajkumarIlanchelian
@anil1973 @Any chance you are participating in our Insider program and saved this document in that version? If yes then this was a schema changing update and hence you will not be able to open it in current production until early next week when we are planning to deploy to production.
if you are not part of Insider then discard the above. Would you be able to share this design with us to take a further look?
Rajkumar Ilanchelian
Autodesk Fusion
Join Fusion Insider
