- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hi guys, new on here and could do with some help. I've tried to search but i suspect i am not using the right terminology. I will try and explain myself the best I can.
The issue I think I am having is that when I am using the line tool to create rails for the loft tool to follow between two 12 sided pentagrams, one slighter smaller than the other. even if I cancel the line tool between each line the software still chains some parts of my lines together rather than treating them as individuals. so when I use the loft function it sees them as one zig-zag rail rather than what i intended them to be which is straight individual rails.
in the picure below you can see it, it sees rail one as 5 lines making a zig zag, but rail two is a single line.
and its resulting in this happening,
the frustration here is that I am repeating what I have already done, twice! but something has changed on this third attempt and I don't understand what. what i am after is the sides to be made of trinagles like this, but i can't get it to work now and it getting quite frustarating!
any insight would be great
Cheers Dom
