Trouble combining model
I'm having trouble combining my model into a single object that i can then scale or slice into smaller solid objects. I'm sure that i've done the workflow wrong to get to this stage but wondering whether its salvageable or is required to start again
g-andresen
Please share the file.
File > export > save as f3d locally  > attach it to the next post.
günther
davebYYPCU
Surface > Stitch command will create the solid from watertight series of surfaces.
you have one solid in the section view.
you have yellow timeline icons to address.
Might help...
shahriarsifat1802164
By adding stitch, you can add the surfaces. and for the solid body do combine.
Thank you.
Md. Shahriar Mohtasim
Dept. of Mechanical Engineering,
RUET
LinkedIn | Facebook | Youtube (CADs) | Twitter
Autodesk Product Users, BD
If you found this post helpful please hit the LIKE button and for a solution hit the ACCEPT SOLUTION.
Thank you.
