issue with timeline not reflecting edit process and merging with imported object
- Mute
- Permalink
- Report
i wasn't sure how to title this properly, i am fighting the timeline to adjust the position of one of the components after the fact.
it's for positioning the knobs on a guitar, i want to move one of the potentiometers but keep the prametric creation of the fileted edges of the cutouts
here's what i did:
- imported the potentiometer model (modeled in fusion) and positioned it
- duplicated the potentiometer component and positioned it
- duplicated again and positioned that
- modeled a cylinder to use as a boolean to cut out a recess and moved it with 'point to point' so it references always on the top of the poti pole.
- combined via cut and fileted the borders of the cut out recess.
now i realise that one of the potentiometers isn't positioned properly so i want to move it. Since i have history on and followed a pretty clean workflow i thought i could now just scroll back in the timeline to where i positioned the 3rd poti and move it somewhere differently and when i'd go back to the end of the timeline it would have the poti including fileted cutout recess at the new position.
Unfortunately i am unable to find a place in the timeline where i could move it it looks like some of the operations used to create the potentiometer in the first place has been merged with the timeline so the original modeling workflow was lost.
How would i go about something like this ? Is there a way to fix this or should i go back in the timeline and redo the operations differently, what do i need to be aware of so that this works ?
Here's a screencast where you see meunsucessfully trying to figure out where to go in the timeline to move the poti.
GENERAL DISCLAIMER: if there isn't a file attached to my posts then there is a reason for it. wherever i can i will attach a file for troubleshooting.If no file is attached i will always try to explain as clearly as possible with illustrative screenshots. when i have an issue that can only be helped by attaching a file which i cannot share publicly i won't ask about it here.
