So I'm trying to simulate the heat coming off of an LED and flowing into the various parts of the assembly.
When I have only 2 components (the stand on which the die sits on and the die itself) the simulation solves just fine. Same thing with any 2 other components, if I just have the die and the Silica gel encasing it, the thermal simulation seems fine.
The problem comes when I want to solve the simulation with the silica gel, the die, and the copper stand (not to mention there's also other components that are attached but I can't even get 3 separate components to solve)
When I hit solve and there's 3 components in the simulation, instead of solving correctly it says everything is 20C.
The really weird part is that it doesn't mess up when I use an applied temperature instead of a heat source or convection load (when I'm solving with 3 components). When I use a heat source the simulation basically acts like it's not there.
