Issue with Thermal Simulation - Everything is the same temperature... sometimes?
So I'm trying to simulate the heat coming off of an LED and flowing into the various parts of the assembly.
When I have only 2 components (the stand on which the die sits on and the die itself) the simulation solves just fine. Same thing with any 2 other components, if I just have the die and the Silica gel encasing it, the thermal simulation seems fine.
The problem comes when I want to solve the simulation with the silica gel, the die, and the copper stand (not to mention there's also other components that are attached but I can't even get 3 separate components to solve)
When I hit solve and there's 3 components in the simulation, instead of solving correctly it says everything is 20C.
The really weird part is that it doesn't mess up when I use an applied temperature instead of a heat source or convection load (when I'm solving with 3 components). When I use a heat source the simulation basically acts like it's not there.
innovatenate
Autodesk Support
Autodesk Support
Can you try using linear element order in the Simulation Settings and see if that helps? There's a known issue we are already aware that might cause this (referenced internally as ARRO-8124). The linear element order should serve as a work-around though. See the image below for more detail.
Hint: You have to expand the advanced settings.
I hope that helps. Let me know if you have any questions.
Nathan Chandler
Principal Specialist
Thanks, that worked. Also, it before I tried your solution I was able to get it to solve correctly only when I applied the heat sources on the edges instead of a face, and it also worked when I applied the heat source on a face that wasn't in contact with anything else. Changing it to Linear just fixed the problem outright without any other workarounds.
