Issue with loft rail
jphalip
Message 1 of 28
jphalip
I'm trying to create a loft between two profiles (a circle and a rectangle with rounded corners) using a spline centerline. My issue is that, even though I've selected a centerline, it still creates another rail on the side. And unfortunately I can't seem to move that rail to when I'd like.
Here's the issue:
I tried to edit the loft and drag the rail's position:
But then after clicking 'Ok', the rail returns to the wrong position:
How can I fix this? Please see the problematic Fusion 360 file attached.
Thanks in advance!
Julien
Replies (27)
Message 21 of 28
wersy
I just found out, it makes a difference depending on where you place the seam.
Message 22 of 28
jphalip
Thank you all for the thoughtful replies.
I recreated the whole design from scratch and constrained all the sketches (except the splines one). Hopefully that resolves any potential misalignments between the sketches themselves. I also tried creating the centerline with arcs instead of a spline, as suggested by @TheCADWhisperer. See the new file attached.
However, even with all of that, the resulting loft still isn't symmetrical... How strange!
Let me know if you can think of a way to make this work. Otherwise I'll try some of the workarounds that have been suggested earlier in this thread.
Message 23 of 28
jphalip
Yes, that's what I had found too, which is why I was asking about how to fix the seam in my original post. My guess is that Fusion 360 takes two points (source and destination) randomly as a guide for the extrapolation. And the fact that the rectangle has rounded corners makes it pick the wrong points. That's fine as a default behavior, but what puzzles me is why it won't save the new point after you drag it and click 'Ok'.
Message 24 of 28
HughesTooling
Did you see my post about spitting the circles in half so you can pick a seam at any quadrant?
Actually seems to work well in the middle of one of the long edges. See attached file,
Mark Hughes
Owner, Hughes Tooling
Message 25 of 28
jphalip
Very interesting. I confirm that this works, thank you!
By the way, how did you split the circles? By deleting the circles and recreating them using 4 arcs?
Using your method, the seem is correctly centered by default, which is great.
However, one thing I still don't quite understand. Why isn't it possible to move the seam and then save the new seam? If Fusion 360 properly saved the change, I think the original sketch would have worked too.
Message 26 of 28
HughesTooling
@jphalip All I did was extend the construction line you had then used break from the modify menu. Also note the Extend option on the same menu.
I think the solid version of loft is just finding the simplest answer, with the surface version you have more control. There are a few situations where the surface tools give better results.
Mark Hughes
Message 27 of 28
daniel_gladyshev
spliting the circle is a hack, but the real problem is how to move the line on the surface, or better simple get rid of it.
i have a similar situation, and it driving me nuts why the surface created by loft on a round object has a line on it.
loft from circle to slot form so they are perfect curves
Message 28 of 28
TrippyLighting
No, it isn't
You are also using the wrong loft setting if you are only getting 1 edge.
If you enable the Keep tangent edges, then you'll get 4 edges with tangent surface transitions and better surfaces.
Then spitting the circle will provide you with better control over the shape.
