Issue saving project files in latest release of Fusion
After updating to Fusion 2.0.1591 I'm experience an issue where if I create a new project document, create a body in it, and go to save it will either :
1. Attempt to save where I will see the new project document in the project folder but when I go outside of the project folder and back in the document is no longer there. Also, may just disappear on its own.
2. The document is there but I get an error from fusion saying it is unable to open the document and to try again later.
I've tried multiple times with the same results. I have also tried restarting Fusion with no change in behaviour. The host machine is a Macbook Pro i7 w 16GB ram and lots of free disk space. Running OSX ver. 10.10.4
I have the log files available.
Any help will be appreciated.
Pete
I logged in under Windows 7 on the same machine and tried the same version of Fusion 360 (ver. 2.0.1591) and I cannot replicate the issue. So it seems that the saving issue only occurs under OSX.
Pete
innovatenate
Autodesk Support
Autodesk Support
Can you forward your the pertinent log files to me at nathan.chandler@autodesk.com and clarify the name of the design in question?
Nathan Chandler
Principal Specialist
Sure, I'll swtich over to OSX and grab the log files and send them to you shortly. I'll also re-test once under OSX.
Pete
innovatenate
Autodesk Support
Autodesk Support
In case anyone else runs into this issue, the solution is documented in the below link.
http://forums.autodesk.com/t5/design-and-documentation/copy-design-amp-drawings/m-p/5780959#M31129
Nathan Chandler
