Isolate a single part/body in simulation results
The subject kind of says it all but here's more detail. After I do a simulation run I want to be able to isolate a part, and keep showing the result for that part. I can do this in the model view but I don't see a way to do it in simulation.
Dan
mcmillr
Hi Dan, when you are showing the Simulation results, you can choose Display/Model View to switch back to the model view. Here you will be able to select a body or component and Isolate. Then use Display/Results View to switch back, and you will only see the results for the part you chose.
It looks like we may have a bug where the Isolate command is not available in Results View. We will confirm this and get it fixed if so.
Thanks for the feedback!
Rob McMillan
Software Architect, Fusion Simulation
Thanks Rob. I'll try that.
Dan
