Generative design
Generative design
Generative design
Hello ,
Can any one do some chair model in fusion 360 taking generative design concept and upload it in You tube or any other social media platform . I am not able to apply the loads in it
mcmillr
Hello, I will try to answer though I am not sure I completely understand what you are trying to do.
Fusion has Shape Generation capability that will produce a result that can be exported to your Model environment as a Mesh.
Fusion cannot perform Simulation on Mesh objects at this time, whether they are from Shape Gen or imported from an STL/OBJ file.
Currently we recommend that you use the mesh as a 'visual reference/overlay', and use the solid modeling tools in Fusion to create a solid that is a good approximation of the mesh shape. You can control the opacity of the solid and mesh object to make this easier.
If the mesh is very intricate, for example a lattice structure, or is has a complex organic shape, this manual method isn't very feasible at the moment.
Rob McMillan
Software Architect, Fusion Simulation
any update on generative design tools in Fusion 360 or other Autodesk Products (dynamo, netfabb, etc.)?
mcmillr
All the publicly available information about Generative design is here.
Rob McMillan
