Is this how to uninstall an add-in correctly?
FrodoLoggins
Advisor Advisor
FrodoLoggins
In the "Scripts and Add-ins" dialogue I can stop the add-in but not uninstall/delete.
If I open the file location and then delete its folder within the InternalAddins folder will that uninstall/delete it or will that just leave Fusion confused why a folder no longer exists?
Or in the case of the CoroPlus addin delete the bundle located in the ApplicationPlugins folder?:
- Time Magazine’s Person of the Year 2006
- Apple M1 Max rMBP A2485 // Latest MacOS // Latest Fusion
- Usually working off files uploaded to Fusion as: Step, STL, SLDPRT. If it matters ask me.
SaeedHamza
Check this : https://forums.autodesk.com/t5/fusion-360-electronics/how-to-get-rid-of-an-quot-add-in-quot/td-p/110...
Saeed Hamza
FrodoLoggins
Thank you but that did not answer my question. I'm on Mac not Windows so it's a bit unclear.
JeromeBriot
To uninstall an add-in on macOs, you simply move its folder to the recycle bin. Even with the add-ins installed by default with Fusion 360.
To find the path to the installation folder, go to UTILITIES > ADD-INS > Scripts and Add-Ins..., select the add-in you want to uninstall and expand the Details section at the bottom of the dialog.
For the add-ins installed by default the name of the folder is the name of the add-in. For third-party add-ins, the name of the folder is the name of the add-in plus the .bundle extension.
Note that the add-ins installed by default are reinstalled when Fusion 360 is updated.
FrodoLoggins
NVM I'm all set.
https://forums.autodesk.com/t5/fusion-electronics/how-to-get-rid-of-an-quot-add-in-quot/m-p/12435103...
