Is this a bug or simply a sketch solver problem
cekuhnen
Mentor Mentor
Message 1 of 9
cekuhnen
making a spline G1 to a line works well when later adjusting the spline
Screen Shot 2019-08-01 at 9.49.13 AM.pngScreen Shot 2019-08-01 at 9.50.40 AM.png
When however you use G2 the spline shape radically changes after the other spline end point will be moved.
From a usability stand point this makes somewhat zero sense.
Screen Shot 2019-08-01 at 9.49.28 AM.pngScreen Shot 2019-08-01 at 9.49.44 AM.png
So what is happening here internally that makes Fusion change the G2 result so drastically.
I never saw this in any other CAD app.
https://drive.google.com/file/d/1VMObOdRDlJh9bsqyZqPxzRmdMAWZxfDR/view
Claas Kuhnen
Faculty Industrial Design – Wayne State Universit
Chair Interior Design – Wayne State University
Owner studioKuhnen – product : interface : design
Replies (8)
Message 2 of 9
TrippyLighting
This was easy to reproduce and I'd say that's a bug.
Message 3 of 9
jeff_strater
@cekuhnen@TrippyLighting - can you share a design that shows this?  I just tried, and it seemed to work OK for me
Jeff Strater
Engineering Director
Message 4 of 9
TrippyLighting
@jeff_strater no, actually it did not ;-)If you look at the length of the g2 tangent handle you'l see that it changes as soon as you move that point. The effect in your case (and in what I tried is simply not as strong as in @cekuhnen's. are but it is present.
If that screencast I made ever completes conversion I'll post it. its very visible there.
Message 5 of 9
jeff_strater
In my case I see a small change.  The tangent handle goes from 95 to 97.  It's a little surprising, but there may be reasons for this.  Remember, the tangent handle lengths are somewhat arbitrary and not precise.  But, I would still like to see a model where this change is large, so the sketch team can look into it.
Jeff Strater
Message 6 of 9
cekuhnen
Hi Jeff
here is the file - it seems this is related to when the tangent handles are not activated.
anyway - did I say sketching in Fusion is a pain ? ...
Screen Shot 2019-08-01 at 11.27.02 AM.pngScreen Shot 2019-08-01 at 11.27.06 AM.png
Claas Kuhnen
Message 7 of 9
TrippyLighting
Message 8 of 9
jeff_strater
Thanks, @cekuhnen & @TrippyLighting .  That's what I needed.  I'll have the sketch team look into it.
[edit] I created FUS-52818 to track this
Jeff Strater
Message 9 of 9
cekuhnen
@jeff_strater  @TrippyLighting
No worries Jeff - this is actually a quite old issue I encountered in the past. Just checked my old test files where I logged it.
when you chat with the sketch team you can als bring up a similar issue with cv curve which act like having brain seizures when Moving cvs. For cvs you fully have to constrain every detail to stabilize it making this a painful experience and labor intensive work flow vs working with less fit points.
that issue is also present since cv splines were released
Claas Kuhnen
