Is there really no way to rotate a construction plane?
Helmi74
Message 1 of 21
Helmi74
I'm just curious and maybe it's just me but i just wanted to rotate a construction plane and noticed it isn't possible.
What i wanted to do: Creating a sketch in relation to an existing body. That sketch should be a defined distance from the existing body and then rotated backwards by 30 degrees.
I though doing this with a construction plane would be the way to go but then i assume i would have to add one or more additional geometry to create this construction plane to. Why not just enable me to rotate the offset plane? All i seem to be able to do is to make it offset to an existing face.
Any hint? Probably i'm just totally missing something!?
Frank / @helmi
Established 1974. Internet addicted since 1994. Collector of Kudos.
Replies (20)
Message 21 of 21
MichaelT_123
Hi Frustrates, ... and Smoothers,
The natural way in the circumstance is ....
  • create a component
  • in it, draw a sketch on one of the component's origin plane
  • rotate, translate, ... the component ... with a drawn-in-it sketch ... at will.
I have forgotten to add that:
  • using coordinates (origin, axes) of both a parent and a child component it could be possible to position the latter parametrically ... but only if TF360 add Position Feature to recalculation (parametric) loop. Have a Hope !!!
Regards
MichaelT
MichaelT
