Can't delete designs
fleckingerre
fleckingerre
Hi!
Every time I right click any design and select delete I get the message: "This desing is in use and cannot be deleted".
Many Greetings!
Remo
Oops, wrong thread!
Could you give a screenshot or something to give a better idea where you're referring to?
Jesse
fleckingerre
Thanks for your enthusiasm, but this is nothing that can be solved with the right way to use Fusion360. This can only be solved by people having access to the Servers. I already sent a Mail. Just forgot that I had the support mail address.
Many Greetings!
Remo
innovatenate
Autodesk Support
Autodesk Support
It sounds like you may be running into an issue due to X-Ref's. Check out the below post for more information.
http://forums.autodesk.com/t5/design-and-documentation/unable-to-delete-a-previously-linked-design/m...
Let me know if you have any questions.
Nathan Chandler
Principal Specialist
scottmoyse
I have a customer with this issue as well. It's just a single Design, he hasn't got into doing Distributed Design yet... and the error doesn't match the one linked to in @innovatenate's reply above. It's not open on any other computers.
As you can see, I managed to rename it though.
Scott Moyse
RevOps Strategy Manager at Toolpath. New Zealand based.
Co-founder of the Grumpy Sloth full aluminium billet mechanical keyboard project
