I don't think thats what lukephigetti is asking for.
Usually fasterners are already part of the component/subcomponent structure of a design. That's where they get in the way, meaning when you adjust a (parametric) design you often need to loacte the sketch for editing in a subcomponent. If you have plenty of imported standard components, nuts, bols, screws, washers, locating pins etc. having to visually sort throug that "rubble" of parts is cumnbersonme.
The other case is that you have changed your design and find that you need different fasternes but these are in a differnt assembly. Then yopu need to traverse down that assembly tree and find the these parts there.
It is easier to locate these in a folder/category. A more flexible approach would be tags and filters. Then you can assign more then one tag to a part (place parts into more than one categroy) and filter for multiple tags.
