Is there a way to offset on more than one line at a time?
I'm working on a shape that requires a lot of offsets but I can't seem to figure out how to do this operation on more than 1 line at a time. Is there a way to apply to multiple lines at a time instead of doing it one by one, which is a bit tedious?
sanket223.patil
 Do you mean offset sketch elements ?Can you explain about your sketch which you are trying to offset . Can you export the file . If you are trying to offset a sketch element , you should tick the chain selection .
Sanket Patil
Mechanical Engineering
Expert Elite
etfrench
Lines, arcs, etc. must have coincident endpoints in order to be offset at the same time.   If the endpoints are coincident, you can extend the selection.
ETFrench
Thank you so much for responding to my question. The question is if I can highlight several loops/lines at ones because I'm trying to create a thickness of 2.2mm for all the lines. I can Offset them one at a time and if I can select multiple, it'll make it easier.
TheCADWhisperer
Would a Shell feature be easier than offsetting sketch elements?
Can you File>Export and then Attach your *.f3d file here?
Do you have a link to an image of something similar (or word description) of your Design Intent?
