Is there a way to move a components along a component path?
chrisparris01
chrisparris01
I and making a robot track using rubber conveyor belt and bolting on treads on the outside. I extruded the rubber track, and in a separate drawing s sketched and extruded the tread. I then brought the tread into the track drawings and placed it on the track using a rigid joint. Then to pattern the tread around the track i used the pattern along path, it works great right up until i press "OK" in the dialogue box an then all the treads "fall off the track.
I am obviously missing something?
promm
@chrisparris01,
Can you create a video or take a screen shot of before and after.  I am having issues with replicating the workflow you describe.
Thank you,
Mike Prom
chrisparris01
Here you go please see attached, i have found Fusion 360 intuative so far!! Thanks
promm
@chrisparris01,
I was unable to replicate your results.  Are you grounding or applying a joint to the origin to track before applying your joint to the tread?  Would you be willing to share you model?
Thank you,
Mike Prom
chrisparris01
Mike,
I did apply a joint, but did not ground the track, when I get back to my desktop i will try it and let you know. If not i will share my modle and take it fom there. Thank you.
chrisparris01
After grounding the track, it was easy thank you. Unfortunatley the design concept has changed and I now have a problem joining the concaved wheels with the top bar of the chain. I want to align the wheels onto the top bar of the chain, so I can modle the rest of the machine with driver portion in place?
promm
@chrisparris01,
The best way to accomplish what you are trying to do is the following:
1. Create a sketch with a point in the center of the arc
2. Create a joint origin
3. Use the joint origin when apply joints.
Here is a video showing the workflow.
http://autode.sk/21y9Wzc
Cheers,
Mike Prom
