- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hey guys. I'm trying to export a model I made to an SVG. I want to use it in an Xtool (laser cutting/engraving software). The software will read SVG, DXF, PNG, JPG, JPEG, and BMP. I saved a DXF file but it doesn't import the holes in the model. Specifically, it's a model of a piece of notebook paper. It's got 6 holes and obviously the outline of the paper. I did points and off the points made holes, modeled the "paper" to the thickness and set the hole size. When i import the DXF file into xtool it doesn't import the holes. I figured my best bet (and would work with other software) would be an SVG.
