Is there a way to Export to SVG
SuzukiGS750EZ
SuzukiGS750EZ
Hey guys. I'm trying to export a model I made to an SVG. I want to use it in an Xtool (laser cutting/engraving software). The software will read SVG, DXF, PNG, JPG, JPEG, and BMP. I saved a DXF file but it doesn't import the holes in the model. Specifically, it's a model of a piece of notebook paper. It's got 6 holes and obviously the outline of the paper. I did points and off the points made holes, modeled the "paper" to the thickness and set the hole size. When i import the DXF file into xtool it doesn't import the holes. I figured my best bet (and would work with other software) would be an SVG.
g-andresen
Create a new sketch > project body and holes into > rightclick > save as DXF
otherwise:
share the file for reply
File > export > save as f3 d on local drive > attach to post
günther
SuzukiGS750EZ
So, you're saying copy and paste the body into a new project? Is the issue the fact that it's extruded and 3D or?
SuzukiGS750EZ
Here's the file. I want to convert it to .SVG and .DXF. The .SVG would be the more preferred.
g-andresen
As you have selected the hole function, there are no circles in the sketch.
You must therefore project the body with the holes into a sketch and then save it as DXF.
günther
SuzukiGS750EZ
Video is working. Thank you!
tgelinasZZTN9
Community Visitor
Community Visitor
I found a fusion 360 add in that allows you to export .svg directly, just make sure to restart fusion once you have add the plug in;
Fusion 360 add in for .svg export.
