Is there a way to easily and quickly center a part/assembly without using the align tool?
FrodoLoggins
Advisor Advisor
FrodoLoggins
Basically like an align tool that auto selects the dead center of the part/assembly and aligns the X/Y/Z at the same time to whatever I select (like the point on the gizmo). Maybe have an option for the bottom of the part to be flush with the XY plane like so:
Screenshot 2023-07-11 at 1.09.36 PM.pngScreenshot 2023-07-11 at 1.09.42 PM.png
Right now if I want a part to be centered around the gizmo, I use the align tool 3 times (unless a snap point happens to be centered which I would not trust because sometimes snap points are close but not dead center) and then the move command 3 times (dividing the distance in two.)
- Time Magazine’s Person of the Year 2006
- Apple M1 Max rMBP A2485 // Latest MacOS // Latest Fusion
- Usually working off files uploaded to Fusion as: Step, STL, SLDPRT. If it matters ask me.
g-andresen
with the Rigid Joint and the "Between Faces" option, this is no problem.
günther
