Is there a way to add Design User Parameters to a Drawing Table?
TStudwell
TStudwell
I have a relatively simple design (A parametric Picture Frame) partly to test workflow and partly because I need a picture frame 🙂
The design seems solid and I can vary the User Parameters to define mat size, frame width, etc.
I have made a corresponding Drawing file of this design and the dimensions on all the part sheets adjust properly with each parameter change.
However, what I would like to do is have a Sheet in the Drawing File that has a Table showing the User Parameters used for that particular instance.   Is there a way to insert a table and put User Parameters in the table on a Drawing Sheet?
TIA, Fusion Amateur..
P-BvanWyk
Good day @TStudwell,
This is an interesting request, I can see the benefit for setting up templates and having the fields populated.
I have not seen any way to link parameters into a table in the drawing workspace.
Please click on Accept Solution to help other community members solve their issues.
Also, consider giving a Like to the comments that you feel added value.
Kind regards,
Pieter-Ben van Wyk
g-andresen
These are reflected in the dimensions of the views.
Is it perhaps to show deviating available sizes in the table.
Günther
