Is there a "Extrim" function in fusion 360 just like in autocad?
Message 1 of 9
I could not find any solution for this. I would like to trim everything outside a (for example) circle. Is there any option for this? Otherwise I just need to trim each line one by one. In short, just like this video. I need such solution. Thanks for the support.
https://www.youtube.com/watch?v=dMOvAo6bkYQ
Replies (8)
Message 2 of 9
TheCADWhisperer
File>Export and then Attach your *.f3d file here.
Message 3 of 9
wmhazzard
I don't think Fusion has such a command but if you select the trim tool and then left click and hold, you can sweep over lines and trim as you go.
Message 4 of 9
Hi, please see the file in the attachment. I want to trim everything outside the circle. Thanks
Message 5 of 9
Hi, unfortunately the lines are so that when I trim everything there are small lines that are still there. ı need to check them one by one via zooming to each section which does not work for me. Thanks
Message 6 of 9
TheCADWhisperer
Your sketch in not fully defined.
Pattern Features - not sketch elements.
Back in a few minutes with correct technique....
There are a hundred variations on this basic theme, depending on your true Design Intent.
I accidentally entered the wrong spacing in my attached file, but you can easily edit...
Message 7 of 9
Hi, thank you. But I dont want to extrude the selected section so that the rest just disappear. I know that but what I am asking is, just like the example video in my first post, if I can just delete everything inside/outside a shape.
Message 8 of 9
TrippyLighting
@Anonymous wrote:
... but what I am asking is, just like the example video in my first post, if I can just delete everything inside/outside a shape...
That functionality does not exist in Fusion 360, neither does I make a lot of sense in a parametric sketch solver. If you absolutely need it then I'd suggest you stick with AutoCAD.
But if you do want to work in a parametric 3D CAD software you likely need to forget some of your obsolete AutoCAD habits and learn a few new things.
Message 9 of 9
JDMather
@Anonymous
What is your Design Intent, your end goal? (Don't worry about how to get there in Fusion as compared to 2D AutoCAD.)
First describe your Design Intent.
