Message 1 of 10
- Mute
- Permalink
- Report
Hi --
Is there a function somewhere that will give me the volume of a body?
thanks
Betty
Hi --
thanks
Betty
Betty,
From the Browser Tree, #Right Click on the Component or Body and select the #Properties from the pop-up menu. That will give you the volume.
Thanks for the reply. That does the trick.
It's interesting that the volume from fustion is always a bit higher than the material volume calculated by shapeways.com, which is the 3D printing service I use. It will do for comparison purposes between fusion models.
Betty
Hi Betty - the calculation done by Fusion is on the Brep (smooth, accurate surfaces) whereas the model uploaded to Shapeways is a mesh (non-smooth, approximated polygons) so the volume calculation between these two types of models is always going to be different *.
Hope this helps,
Indy
Edit: * unless dealing with very simple geometry, such as a cube.
I'm working with the same issue, however, when using the properties window, the volume comes up as 0.00. I've tried pulling up the properties when it was just a body, then tried making the body a component, same thing, 0.00 volume.
What am I missing here?
The best way is to share the model and include pictures of exactly what you're seeing (and what you're trying to achieve if you're trying to get a certain shape).
There are a few ways to share your model, have a look at the page below and decide on the one that is best suited to you 🙂
Thanks!
Indy
Is there way to get multiple bodies volume at once? I tried selecting all bodies and right click on one of them then Properties, but it gives the Volume only of that Body.
Create a component, put the bodies in it and read the volume of the component.
günther
