Is there a measurement that gives me the volume of a body?
itchytoes
Message 1 of 10
itchytoes
Hi --
Is there a function somewhere that will give me the volume of a body?
thanks
Betty
Replies (9)
Message 2 of 10
rwillardphil
Betty,
From the Browser Tree, #Right Click on the Component or Body and select the #Properties from the pop-up menu.  That will give you the volume.
Message 3 of 10
itchytoes
Thanks for the reply.   That does the trick.
It's interesting that the volume from fustion is always a bit higher than the material volume calculated by shapeways.com, which is the 3D printing service I use.   It will do for comparison purposes between fusion models.
Betty
Message 4 of 10
wilkhui
Hi Betty - the calculation done by Fusion is on the Brep (smooth, accurate surfaces) whereas the model uploaded to Shapeways is a mesh (non-smooth, approximated polygons) so the volume calculation between these two types of models is always going to be different *.
Hope this helps,
Indy
Edit: * unless dealing with very simple geometry, such as a cube.
Inderjeet Singh Wilkhu
Product Owner - ASM
Autodesk, Inc.
Message 5 of 10
jrugh
I'm working with the same issue, however, when using the properties window, the volume comes up as 0.00.  I've tried pulling up the properties when it was just a body, then tried making the body a component, same thing, 0.00 volume.
What am I missing here?
Message 6 of 10
wilkhui
Hi there - can you share your model?
Indy
Product Owner - ASM
Autodesk, Inc.
Message 7 of 10
jrugh
Sorry, I'm rather new to this program, what would be the best way to do that? screenshot, or share the model
Message 8 of 10
wilkhui
The best way is to share the model and include pictures of exactly what you're seeing (and what you're trying to achieve if you're trying to get a certain shape).
There are a few ways to share your model, have a look at the page below and decide on the one that is best suited to you 🙂
How to share a Fusion 360 design
Thanks!
Indy
Product Owner - ASM
Autodesk, Inc.
Message 9 of 10
Is there way to get multiple bodies volume at once? I tried selecting all bodies and right click on one of them then Properties, but it gives the Volume only of that Body.
Message 10 of 10
g-andresen
Create a component, put the bodies in it and read the volume of the component.
günther
