Is the software stable??
Message 1 of 28
Hi all,
I am spending hours on my personal design. For the second time today, it seems it passed a crash, and I lost everything. I have few sceen caps from what happened during zoom in/out (mid mouse) just before crashF3602.GIF.
Is that normal??
Many thanks in advance!
Avi
Replies (27)
Message 21 of 28
PhilProcarioJr,
What is windows scaling? under Win-10.
Message 22 of 28
PhilProcarioJr
Windows scaling refers to the size of text and icons in windows, I had an issue very much like you had in your screen shots and my scaling was set to 125% when I switched it to 100% everything in Fusion looked right (IE no icons outside the boxes).
http://www.windowscentral.com/how-make-text-apps-bigger-windows-10
Hopefully this fixes at least one problem your having.
Phil Procario Jr.
Owner, Laser & CNC Creations
Message 23 of 28
daniel_lyall
@Anonymous if you look at that link I posted it shows how good you graphics is, it's not good the miumum for fusion is 1 gig, 2 gig is fine so hardwear yes
Daniel Lyall
The Big Boss
Mach3 User
Facebook | Twitter | LinkedIn
Message 24 of 28
To be honest - I really appreciate all the people responding here.
I am kind of highly frustrated. Nothing seems to work. While yesterday was more or less ok, today everything, simply everything doesn't work. Same design, no real progress or any additional layers to make it complex.
Still - F360 freezes with that blue circle on screen. Can not edit anything, nothing on tool is active, can not even zoom in or out.
I really got attached to this kind of interface. Willing to give it another chance, only if I knew what I should do here (rathan than to BURN with 2 gallons of gasoline my brand new LT). I'm willing to give it another chance before I move on to the web based things such as crappy 123D Design or OnShape.
Anyone - ??
Message 25 of 28
@Anonymous
Back up a bit here.
Are you running Windows 10 in boot camp on a Mac?
Or is it a Windows machine?
If you on a Mac book. It could be a issue that your running the Windows fusion when you don't need to.
it used to run fuison for a little while on my wife's Mac book air. It has a HD????? Chip but it never gave me big problem just using it to do basic things.
Is this the case here?
Message 26 of 28
TrippyLighting
Your problems are hard to diagnose based on a screenshot. Could you post your design or share a link to it ?
Message 27 of 28
That might be a bit hard if he has problems using fusion?
Message 28 of 28
TrippyLighting
That might be the case, however, if the problem is editing objects then it should not be a problem to share the design via the data panel in Fusion or via A360.
Neither of these require opening the design.
Actually from A360 you don't even need a computer, you can share designs from your smart phone.
That would not seem to be so hard 😉
