WHERE IS MY BODY?
WHERE IS MY BODY?
fritter63
WHERE IS MY BODY?
fritter63
I have a drawing with a body that is invisible and it should not be. It is keeping me from being able to CNC it.
See this screencast for detailed explanation:
https://knowledge.autodesk.com/community/screencast/d25f92e8-01b7-49a4-a835-0baf8e0114dd
Attached is the f3d file for it. Can anyone tell me why this body is gone now?
So much for my plans of being productive on the CNC machine today!
jeff_strater
Hi @fritter63,
It looks like Extrude4 removes all the material from this body:
I'm not sure what the intention of this Extrude is, but this is what I get when I edit it:
Most likely, you intended to extrude a different profile here.  Perhaps some edit has caused Fusion to pick an incorrect profile, but it's hard to say for sure without knowing what edits have occurred.
Anyway, I suspect editing this Extrude will get you the results you want
Jeff Strater (Fusion development)
Jeff Strater
Engineering Director
HughesTooling
It looks like you should have hidden the body when you made the last 2 extrude cuts. Here's what I get when I go back and hide the body while editing the extrudes.
And here's the CAM after reselecting the body.
File attached.
Mark
Mark Hughes
Owner, Hughes Tooling
fritter63
Doh! Good catch, thanks Jeff!
