Is it possible to edit an older sketch in relation to a current change?
JohnSays
JohnSays
In my current case I have created a sketch and revolved it around a part which I previously created. However, I found it necessary to modify that first part. I would like to see how the original sketch relates to the newly shaped part. Is that possible. From what I can tell the editing of a sketch will always show the sketch in relationship to the parts as they appeared at the time the sketch was first created.
Update:
I just found that I can modify the sketch without going into edit mode. Very nice and that solves my current problem. I can see the exact relationship of the sketch to my current design. So this is solved and I am leaving the post here because it was a problem for me for many months that I had not tried to figure out until now.
innovatenate
Autodesk Support
Autodesk Support
It might be helpful to note that there is a show dimension command on the right click menu of the sketch that can be helpful. This will let you edit the dimension without need to edit the sketch first.
Nathan Chandler
Principal Specialist
JohnSays
Yes! Very helpful. Thank you.
