Is it only me? Problem loading McMaster cart
alessiol
Message 1 of 24
alessiol
Hello!
I have tried to look online but did not find anyone else complaning about it, so I am afraid for some reason I am the only one.
Since a week I can not open the McMaster cart. I have attached a picture to show what I see.
Any thoughts?
Thank you.
Best,
Alessio
Replies (23)
Message 21 of 24
jhackney1972
Then do not do it if you do not want to.
John Hackney, Retired
Message 22 of 24
jhackney1972
It is entirely up to you.  Do not create a new profile, it is your decision.
Message 23 of 24
alessiol
What I meant is that since the problem I am having at login it's only with Fusion, I would prefer to solve it without the need to use a separate profile to run it.
Anyhow I have made a new Windows Administrator profile and it indeed Fusion works. Now I would need to know what Fusion is actually looking in the windows profile files to maybe copy it over to the old Windows profile. I have tried to search for "restore windows profile to default setting" but didn't find the solution i was looking for.
Message 24 of 24
alessiol
To summarise in case someone is facing the same problem. The "solution" was to make a new Windows Administrator profile as jhackney1972 suggested. For some reason upon a clear unistall and reinstall of Fusion360 something got corrupted in the default Administrator profile I was using (probably in the registers). The PC runs normally, but Fusion won't start properly. I know it's not a solution, since I need to switch to the new profile everytime I want to use Fusion, but that it's the best I could get. Thanks everyone for the help.
