Intrinsic parameters
jean-michel_legoff
Message 1 of 17
jean-michel_legoff
I was wondering if it could be possible to use intrinsic parameters without creating them.
In a particular construction I want to get the length of an extrusion (for exemple) but without creating a parameter called "Lengh"
I want to keep this length dependant from other references.
I can't find any way to get this length as it is caculated intrinsecly in the extrude feature....
Replies (16)
Message 2 of 17
g-andresen
Give an example of what you want to do.
günther
Message 3 of 17
jeff_strater
not sure what you are asking here, but if you want the ability to create a parameter "on the fly" while creating an extrude, try using "length=30" syntax.  This creates a favorite model parameter with the name "length"
Jeff Strater
Engineering Director
Message 4 of 17
davidSWEUU
I don't know if this answers the question, but that is a great tip!!!
Message 5 of 17
jean-michel_legoff
Many Thanks but I known this.
What I want is to get the length of an edge which is depending of other references...
I want to use the Rectangular pattern tool.
in the distance field I need to enter a distance... but I don't know it.
I can on the fly measure the length of the long edge by selecting "measure" and the edge. But the value is taken only at that moment...
If I modify my rectangle by draging the short edge, the value don't update...
 distance is not really driven by the edge's length but is only computed on the fly.
Message 6 of 17
jean-michel_legoff
could it be possible to save a measurement as an analysis and get this value in the parameter space?
Message 7 of 17
g-andresen
If I create a sketch and dimension it directly with the creation of favourite parameters, I can also access these in the rectangular pattern.
günther
Message 8 of 17
jean-michel_legoff
Yes, I agree
But even if it is on the fly you have created the parameter "Length", so that length coul no more be edited interactively or defined by external references...
Message 9 of 17
jean-michel_legoff
I mean if my sketch is driven by 2 components as the cube in this screenshot
the the length of the long edge is dependant of the space between the cubes...
and if the spece augment or reduce I want the sketch follows and rectangular pattern too.
this is a basic example.
Message 10 of 17
g-andresen
.. no words
günther
Message 11 of 17
jean-michel_legoff
yes but the result is the same,
you have created a parameter "Length_full" by numerical value, it's not the result of a referencing...
Message 12 of 17
TrippyLighting
What @g-andresen is describing is referencing a driving dimension.
What @jean-michel_legoff is looking for is to reference a driven dimension. At this point that isn't possible. There is a heated thread about Fusion 360 current inability to reference driven dimensions, but I chose not to link to this here 😉
Message 13 of 17
barry9UDQ6
How about you don't use rectangular pattern, but create each rectangle manually.
In my sketch below, the 2 lines highlighted in blue have an equal constraint, and are driven by the other dimensions?
Message 14 of 17
jean-michel_legoff
OK,
As I said it is a very simple case, and it is not representative of the final work, except that I shall have use a value which I can't drive but which will be always only driven by the model.
So In order to get a fully parametric model this value needs to update automatically.
But if it's not possible for now, OK, I shall continue to manage it by hand.
So I have better to ask a feature request apparently.
Message 15 of 17
TrippyLighting
No need to. I's been asked for fervently in the thread I did not link to 😉
Message 16 of 17
TheCADWhisperer
You can use Driven Dimensions (reference dimensions) as parameters in Autodesk Inventor Professional (for more years than I can remember, but I suspect 10+ yrs).  So the folks across the hall at Autodesk are aware of the utility of this functionality.
Message 17 of 17
jean-michel_legoff
Yes it looks like there are some cool features in Inventor that Fusion 360 didn't heritate... "yet",  I hope
