Intersecting two solids at different heights along a 2d curve
I'm trying to connect two solids at different heights using a 2d sketch profile.  (I want the 3d curve to follow the 2d sketch curve)
innovatenate
Autodesk Support
Autodesk Support
Can you share the file either by uploading and archive file to this thread or by sharing a public link?
How to Export an Archive File:
http://knowledge.autodesk.com/support/fusion-360/troubleshooting/caas/sfdcarticles/sfdcarticles/How-...
How to share a public link:
http://knowledge.autodesk.com/support/fusion-360/getting-started/caas/screencast/Main/Details/2b2054...
Nathan Chandler
Principal Specialist
here is the archive file....
innovatenate
Autodesk Support
Autodesk Support
So here's a couple of suggestions:
Let me know if these help or if you have any questions.
Nathan Chandler
perfect! thank you so much!  now the last step is to fill that are into a solid to connect the 2 together to make it one solid piece.  i have attached another file
innovatenate
Autodesk Support
Autodesk Support
Here's another video showing how to use the Patch workspace > Loft command to connect those two faces.
You can then use the Stitch command to stitch all of the surface bodies into a solid body. You could also use the Boundary Fill command for that.
I'm not sure if this is what you're looking for or not, but I hope it help to get you closer. Feel free to ask questions or post a picture of what you're making, I'm happy to help.
Nathan Chandler
