intersecting sweep - adding detail to a wing
nemo_uk
nemo_uk
I would like to sweep a profile along a curve which flows around a wing.  To carve out some detail representing the ailerons on a aircraft that will be printed as a solid.  Problem is the sweep will intersect with itself at the trailing edge of the wing.  Is there any way around this ?  Break the curve into top and bottom and do two sweeps ?
indentindent
profile around trailing edge of wingprofile around trailing edge of wing
TrippyLighting
Yep. Cut the piece out. Chamfer all edges. And combine-joint it back together.
I'm guessing the thickness varies... cut aileron out, draw a line on face at hinge line, create planes at angles on line then split body (aileron) at planes and reattach
nemo_uk
cutting / chamfer / combine did the trick, thanks very much.
