Intersect sketch accuracy issue.
mcramblet
Message 1 of 17
mcramblet
I'm having an issue with very small gaps existing in a sketch when intersecting a body with the sketch plane. As can be seen in the screen cast, I stitch the surface patches with a tolerance of .001 of an inch and the patch seams close correctly. But when I intersect the body with the sketch plane and zoom in, there are tiny gaps.
Here is a zoomed in image of the sketch lines:
Here is the same set of points, but also showing the surface used to intersect:
The surface doesn't have a gap, but the sketch certainly does. Any thoughts on why this is?
Replies (16)
Message 2 of 17
jeff_strater
Hi @mcramblet,
This could well be an accuracy issue.  Would it be possible to share the design, so we could take a look at it?
The interesting thing about the images you shared is that the profile seems to be correct, even though the sketch line has this gap.  Not sure what that means, to be honest.
Jeff
Jeff Strater
Engineering Director
Message 3 of 17
mcramblet
@jeff_strater-
I sent you a private message with the link to the file.
Message 4 of 17
jeff_strater
Thanks, I'll look into it, and follow up with you on PM.
Jeff
Jeff Strater
Message 5 of 17
jeff_strater
Actually, I'll respond here because this may be valuable information for others.
To be honest, I did not watch the video closely when I replied.  My mistake...
The problem here is related to the way that Stitch works in Fusion.  When you specify a tolerance in Stitch, Fusion does not move the edges of the surfaces at all.  Instead, it creates what we internally call "tolerant edges".  Normally, an edge is an infinitely thin curve.  However, a tolerant edge can be visualized as more of a tube, with the diameter of the tube being the necessary tolerance to join it to other edges, and the centerline of the tube as the source edge curve.  The tolerance you put into Stitch is the maximum size of that tube that you will allow.
So, the stitch succeeds, but contains these tolerant edges.  The BRep surface itself is generally OK to work with, but you may encounter downstream problems with the model (if it's a solid, booleans can fail, to-face terminations can fail, etc).
But, in the case of the Sketch Project Intersect command, we have a problem.  We are projecting the intersection of the sketch plane with the body, which in most cases, is the intersection with the faces, and those are in their original positions.
Here's an exaggerated view of what is happening.  Here are some faces that have gaps between them:
And here is my interpretation of what happens when you stitch those faces with a large tolerance.  The red tubes are the tolerant edges.  But, the faces have not changed at all:
If we have a sketch plane in the middle:
This is what the intersection will look like:
In your case, you will see that the distance between the sketch points is within the tolerance (0.001) that you specified:
Hope this helps clear up what is going on.  The real problem is in the source data for this model.  It's pretty inexact, is my guess.
Jeff
Jeff Strater
Message 6 of 17
mcramblet
Very interesting. That explains why I've never had any luck bring these types of surface patch files into Fusion. These are sculpted/voxel models that are then surfaced and supplied as unstitched surface patches in an IGES file. A very manual process and doesn't have the tightest tolerances.
So in a nutshell, the lesson here is that surfaced files coming into Fusion must have tight tolerances before being imported, because the existing edge tolerances are "fixed" and won't actually be altered by the stitch command. Correct?
I'll have to play with the source files a bit more and see if I can tighten them up before bringing them into Fusion. Thanks for the explanation.
Message 7 of 17
Encountering the same problem?
I created vertical profiles with sketch
Then I created horizontal profiles using project Intersect
Then I created two 3D lines  giving a knuckle in the shape
So every point should be connected , coincident
In my screencast you see the profiles
creating the loft is frustrating
Using the vertical profiles then I can use the knuckle lines as rails also the horizontal ones
But then I get the warning points not connected
I checked it several times
Using the verticals as profiles the same problem
sse screencast
Message 8 of 17
I am having a similar problem... I am attempting to project reference points for the edge of a body though a selected sketch plane. - Using the 'insect' tool. The projected reference line is not on the edge of the reference body.
Message 9 of 17
cekuhnen
@Anonymous
I think sometimes this is a graphic resolution inaccuracy while the geometry is correct.
Change the body display resolution and then see if this still happens.
Claas Kuhnen
Faculty Industrial Design – Wayne State Universit
Chair Interior Design – Wayne State University
Owner studioKuhnen – product : interface : design
Message 10 of 17
I don't believe this is a graphics issue. I have found this problem as a result of a failed loft, I get the error: The rails don't touch all profiles. When I went looking deeper as to why, I noticed the intersect problem.
Message 11 of 17
cekuhnen
@Anonymous can you share the fusion file?
Claas Kuhnen
Message 12 of 17
razohrer
Observer
Observer
Did you ever find a solution to this? Im coming up with the same problem. Its very limiting and frustrating to say the least. Seems like it works for some people but not others.
Message 13 of 17
I got the exact same problem. And its random. (i cant recognize a pattern)3375745d05b0ebc94b5c5fdcf9445431f2168d7d.png Tried same and different profile, even a simple shapes. Never connects how it should. And it does it very random.
1st edge sketched, intersected line perfect.
2nd edge sketched, intersected line offseted.
Message 14 of 17
davebYYPCU
Looks like the trailing edge point is higher than the sketch plane you projected to.  You may have to rotate the airfoil so that Leading Edge and Trailing Edge points are on the same plane, you want to use.
Purple line is a projected intersection curve, so the airfoil is not lined up.
Might help.....
Message 15 of 17
I had that idea in mind before, i added "leveled" points on airfoil spline, didnt work. Then i just sketched regular rectangle (simple line tool) to check if missalingmet was the problem. Unfortunately, no luck. Visually, everything was connected but Loft again gave same old errors. "Not touching all profiles" or something like that.
Message 16 of 17
davebYYPCU
Your last picture, confirms the purple line, does not touch any profile.
Will need the file, to show you, or find the misalignment,
having said that, I had trouble last night with Project > Intersect, myself.
Loft requires super accuracy!!
Message 17 of 17
You were 10000% right!
I searched casts a bit and noticed some users had purple lil circle on the touching point which i didnt have. Even on full zoom it was connected visually but i guess not in code 😐 Talking about super super super precise. Snapping helped.
Ty for fast response and help. I didnt realize how "more" precise i have to be and this extra little thing i have to keep my eye on!
EDIT:
Good news doesnt have to be leveled and after the purple circle, doesnt get offseted.
