Installer crashes OS X 10.9.3
Message 1 of 24
Process:         Autodesk Fusion 360 [44803]
Path:            /Users/USER/Library/Application Support/Autodesk/*/Autodesk Fusion 360.app/Contents/MacOS/Autodesk Fusion 360
Identifier:      com.autodesk.Autodesk Fusion 360
Version:         ???
Code Type:       X86-64 (Native)
Parent Process:  launchd [316]
Responsible:     Autodesk Fusion 360 [44803]
User ID:         501
Date/Time:       2014-06-29 19:58:11.837 -0500
OS Version:      Mac OS X 10.9.3 (13D65)
Report Version:  11
Anonymous UUID:  E1805906-A2C7-57FA-5A8B-F78D2A0D2C60
Sleep/Wake UUID: 543E5296-4A50-442D-8411-3901851106E1
Crashed Thread:  0
Exception Type:  EXC_BREAKPOINT (SIGTRAP)
Exception Codes: 0x0000000000000002, 0x0000000000000000
Application Specific Information:
dyld: launch, loading dependent libraries
Dyld Error Message:
  Library not loaded: @rpath/Qt.framework/QtCore.framework/Versions/Current/QtCore
  Referenced from: /Users/USER/Library/Application Support/Autodesk/*/Autodesk Fusion 360.app/Contents/MacOS/Autodesk Fusion 360
  Reason: image not found
Binary Images:
    0x7fff6e503000 -     0x7fff6e536817  dyld (239.4) <042C4CED-6FB2-3B1C-948B-CAF2EE3B9F7A> /usr/lib/dyld
Model: MacBookPro10,1, BootROM MBP101.00EE.B02, 4 processors, Intel Core i7, 2.7 GHz, 8 GB, SMC 2.3f36
Graphics: Intel HD Graphics 4000, Intel HD Graphics 4000, Built-In
Graphics: NVIDIA GeForce GT 650M, NVIDIA GeForce GT 650M, PCIe, 1024 MB
Memory Module: BANK 0/DIMM0, 4 GB, DDR3, 1600 MHz, 0x80AD, 0x484D54333531533642465238432D50422020
Memory Module: BANK 1/DIMM0, 4 GB, DDR3, 1600 MHz, 0x80AD, 0x484D54333531533642465238432D50422020
AirPort: spairport_wireless_card_type_airport_extreme (0x14E4, 0xEF), Broadcom BCM43xx 1.0 (5.106.98.100.22)
Bluetooth: Version 4.2.4f1 13674, 3 services, 23 devices, 1 incoming serial ports
Network Service: Wi-Fi, AirPort, en0
Network Service: Parallels Shared #0, Ethernet, vnic0
Serial ATA Device: APPLE SSD SD512E, 500.28 GB
USB Device: Hub
USB Device: FaceTime HD Camera (Built-in)
USB Device: Hub
USB Device: Hub
USB Device: BRCM20702 Hub
USB Device: Bluetooth USB Host Controller
USB Device: Apple Internal Keyboard / Trackpad
Thunderbolt Bus: MacBook Pro, Apple Inc., 23.4
Replies (23)
Message 2 of 24
svelez
Thank you for contacting us with the error. May I ask for more information?
To diagnose the issue we will need a copy of the installation log (found at ~/Library/Logs/autodesk.webdeploy.streamer.log), the installation database (~/Library/Application Support/Autodesk/webdeploy/meta/registry), and a list of the contents of the Fusion installation folder. Issue the following command in a terminal:
    ls -lR ~/Library/Application\ Support/Autodesk/webdeploy > ~/Desktop/FusionFiles.txt
The list will then be available on your desktop as "Fusionfiles.txt"
Zip them up and attach them to your reply.
Steven
Message 3 of 24
Thanks, here?s my response to:
Hi sports.racer,
svelez (Employee) posted a new Reply in Help and Support on 06-30-2014 11:43 AM:
Re: Installer crashes OS X 10.9.3
Steven
Message 4 of 24
svelez
I do not see files attached to the post.  If you attempted to attach files by responding with your e-mail client, that is not supported.  Please log in using the web interface and update the reply.
Thanks!
Steven
Message 5 of 24
Here are the files.
Message 6 of 24
svelez
Thank you for providing the requested files.  Unfortunately the error, at least superficially, seems to indicate a missing file issue, but according to the install directory file list, the file is present and should be accessible.  Another possibility is that through some strange accident, you have received the incorrect version of the main application file.  To check this please issue the terminal command:
$ shasum "/Users/dgd/Library/Application Support/Autodesk/webdeploy/production/e65096bbec3d87d91777dfcbc35093d1fb80d087/Autodesk Fusion 360.app/Contents/MacOS/Autodesk Fusion 360"
And ensure that the output is
0eb99db5706599a4570626090e6c4f81db4b7af8 /Users/dgd/Library/Application Support/Autodesk/webdeploy/production/e65096bbec3d87d91777dfcbc35093d1fb80d087/Autodesk Fusion 360.app/Contents/MacOS/Autodesk Fusion 360
If that matches, bypass the Dock and Launchpad by opening the application directly and determine if you still see the error.
Steven
Message 7 of 24
Terminal output is the same as you described.
Launching the app directly results in the problem report dialog with this
Process:         Autodesk Fusion 360 [9510]
Version:         ???
Parent Process:  launchd [320]
Responsible:     Autodesk Fusion 360 [9510]
User ID:         501
Date/Time:       2014-07-01 14:36:25.144 -0500
Report Version:  11
Sleep/Wake UUID: 5E0B4B54-4F3D-47DE-AC17-FD9DBB5846A8
Crashed Thread:  0
Dyld Error Message:
Binary Images:
    0x7fff6c920000 -     0x7fff6c953817  dyld (239.4) <042C4CED-6FB2-3B1C-948B-CAF2EE3B9F7A> /usr/lib/dyld
USB Device: Hub
USB Device: Hub
USB Device: Hub
Message 8 of 24
If it helps here are the package contents Autodesk Fusion 360.app
Message 9 of 24
svelez
Sorry for the delayed response.  I have run out of ideas for identifying the cause of this problem, and I was checking for other potential avenues of investigation.
Since this appears to be at least your second installation of Fusion, I am assuming it has worked in the past, so I am going to ask you to reset and try the installation again.  Firstly, uninstall fusion using the "Remove Autodesk Fusion 360" entry in your Launchpad.  Next, to make certain we are clean, manually delete the following folders from your account if they exist:
  • ~/Library/Application Support/Autodesk/common/
  • ~/Library/Application Support/Autodesk/Autodesk Fusion 360/
  • ~/Library/Application Support/Autodesk/Neutron/
  • ~/Library/Application Support/Autodesk/Neutron Platform/
  • ~/Library/Application Support/Autodesk/Synergy/
  • ~/Library/Application Support/Autodesk/web services/
  • ~/Library/Application Support/Autodesk/webdeploy/
Finally, install again using the Fusion 360 Download page. (<- this is a link, not sure why the style sheet here doesn't make that more obvious)
Steven
Message 10 of 24
No problem I appreciate the help. I have never had Fusion working and have been getting these errors since the first attempt to install. I will try your suggestions and let you know what happens.
Message 11 of 24
svelez
That's not good news 😞
So, I think I know the answer, but I must ask to eliminate possibilities.   Are you using a macbook with a 64-bit processor? (Not that I think they were using 32-bit processors when this one was made...)
Steven
Message 12 of 24
Just tried your instructions and got the same error message. This machine has a Core i7 processor which I gather is 64 bit.
Message 13 of 24
Grasping at straws I unstalled everything, repaired disk persmissions and reinstalled and got the same error.
Message 14 of 24
svelez
Bummer.
Would it be possible for you to package up the contents of your ~/Library/Application Support/Autodesk/ folder to see if what the installer is putting on your machine runs on some of ours?  Do not use zip as that may lose some critical information.  Use tar.gz if you know how, or put it all in to a dmg (one place for instructions: http://www.wikihow.com/Make-a-DMG-File-on-a-Mac)
Also, that will likely be too large to post to the forum so I will be inviting you to a shared folder that you can upload to...
Steven
Message 15 of 24
I have a tar ready to go.
Message 16 of 24
svelez
Hi Dave,
Thanks for the tarfile.... I did manage to uncompress it and get the program you provided to me to lauch.  That said, I did have to make one set of changes to the files to make it less specific to your system.  So, maybe we can start by making the same changes on your system, and see if they help.
Attached is a file that should make your copy look more like mine.  To use it, download it and issue the command:
$ sh ~/Downloads/relo.txt
Run it... if that doesn't help one more diagnostic would be to try would be this command:
$ chmod -R a+rwx ~/Library/Application\ Support/Autodesk/webdeploy
Then, again, launch the application.
If neither of these help, you have mentioned trying on another system you have access to. Have you been able to try that?  How does it differ from this system.  Might you also be able to try from another (new) user account on this same machine and report what that does.
Thanks for your assistance in this matter,
Steven
Message 17 of 24
I've tried the steps you just posted, no good.
I installed on another account on this machine and no good.
Will try again on the other machine later. Thanks for the help.
Message 18 of 24
svelez
*sigh*
Ok, lets see if the dynamic loader debug settings give us any more info.  Issue this command:
$ DYLD_PRINT_OPTS=1 DYLV_PRINT_ENV=1 DYLD_PRINT_LIBRARIES=1 DYLD_PRINT_RPATHS=1 ~/Library/Application\ Support/Autodesk/webdeploy/production/e65096bbec3d87d91777dfcbc35093d1fb80d087/Autodesk\ Fusion\ 360.app/Contents/MacOS/Autodesk\ Fusion\ 360 2>&1 | cat > ~/Desktop/launchrecord.txt
And send us launchrecord.txt
Out of curiosity, are you using a case-sensitive file system?
(The command to determine this is:
$ diskutil info /
Steven
Message 19 of 24
"Out of curiosity, are you using a case-sensitive file system?" Yes it is. I've attached the launchrecord but I have a feeling we know what it is now...
Message 20 of 24
svelez
OK,
I did finally notice a case sensitivity discrepancy.  Unfortunately, we do not support or test against case-insensitive file systems, and this is the second issue related to the configuration that has been encountered.  To receive support, I will have to ask you to transition to a case-insensitive HFS+ file system.
If this is not an option, it may be possible to get Fusion running by re-partitioning a portion of your drive to be case-insensitive and then establishing a symbolic link from "~/Library/Application Support/Autodesk" to a folder on that partition.  However, to be clear, this is just a crazy idea I just thought of, and this configuration can not be fully supported should you continue to have problems.
Steven
