Message 1 of 24
06:02 PM
- Mute
- Permalink
- Report
Process: Autodesk Fusion 360 [44803]
Path: /Users/USER/Library/Application Support/Autodesk/*/Autodesk Fusion 360.app/Contents/MacOS/Autodesk Fusion 360
Identifier: com.autodesk.Autodesk Fusion 360
Version: ???
Code Type: X86-64 (Native)
Parent Process: launchd [316]
Responsible: Autodesk Fusion 360 [44803]
User ID: 501
Date/Time: 2014-06-29 19:58:11.837 -0500
OS Version: Mac OS X 10.9.3 (13D65)
Report Version: 11
Anonymous UUID: E1805906-A2C7-57FA-5A8B-F78D2A0D2C60
Sleep/Wake UUID: 543E5296-4A50-442D-8411-3901851106E1
Crashed Thread: 0
Exception Type: EXC_BREAKPOINT (SIGTRAP)
Exception Codes: 0x0000000000000002, 0x0000000000000000
Application Specific Information:
dyld: launch, loading dependent libraries
Dyld Error Message:
Library not loaded: @rpath/Qt.framework/QtCore.framework/Versions/Current/QtCore
Referenced from: /Users/USER/Library/Application Support/Autodesk/*/Autodesk Fusion 360.app/Contents/MacOS/Autodesk Fusion 360
Reason: image not found
Binary Images:
0x7fff6e503000 - 0x7fff6e536817 dyld (239.4) <042C4CED-6FB2-3B1C-948B-CAF2EE3B9F7A> /usr/lib/dyld
Model: MacBookPro10,1, BootROM MBP101.00EE.B02, 4 processors, Intel Core i7, 2.7 GHz, 8 GB, SMC 2.3f36
Graphics: Intel HD Graphics 4000, Intel HD Graphics 4000, Built-In
Graphics: NVIDIA GeForce GT 650M, NVIDIA GeForce GT 650M, PCIe, 1024 MB
Memory Module: BANK 0/DIMM0, 4 GB, DDR3, 1600 MHz, 0x80AD, 0x484D54333531533642465238432D50422020
Memory Module: BANK 1/DIMM0, 4 GB, DDR3, 1600 MHz, 0x80AD, 0x484D54333531533642465238432D50422020
AirPort: spairport_wireless_card_type_airport_extreme (0x14E4, 0xEF), Broadcom BCM43xx 1.0 (5.106.98.100.22)
Bluetooth: Version 4.2.4f1 13674, 3 services, 23 devices, 1 incoming serial ports
Network Service: Wi-Fi, AirPort, en0
Network Service: Parallels Shared #0, Ethernet, vnic0
Serial ATA Device: APPLE SSD SD512E, 500.28 GB
USB Device: Hub
USB Device: FaceTime HD Camera (Built-in)
USB Device: Hub
USB Device: Hub
USB Device: BRCM20702 Hub
USB Device: Bluetooth USB Host Controller
USB Device: Apple Internal Keyboard / Trackpad
Thunderbolt Bus: MacBook Pro, Apple Inc., 23.4
