Fusion Design, Validate & Document
Stuck on a workflow? Have a tricky question about a Fusion (formerly Fusion 360) feature? Share your project, tips and tricks, ask questions, and get advice from the community.
Inserting DXF files
1 REPLY 1
185 Views, 1 Reply
Inserting DXF files
I am modeling a control box cover. All of the dxf files have a common insertion point of 0,0,0. The first file inserts correctly, but any subsequent inserted dxf files are rotated 90 degrees to the first file. My question is how to correct this.
1 REPLY 1
g-andresen
That's no problem at all.
Create your bodies and edit them if necessary.
Then you can put them in the right position.
günther
