inserted step file disappears when I try edit a sketch
nor500
nor500
I would like to project a geometry from an inserted step file to a sketch. However when I enter into sketch edit mode the step file disappears so I cannot do the projection. When I exit sketch edit mode then the step file appears again. I am a beginner, so probably I don`t understand what it is happening. Can anybody help me with that? Thank you
g-andresen
Please share the file.
File > export > save as f3d on local drive  > attach it to the next post.
günther
nor500
Thanks I am sending. I renamed the parts to understand more easily.
davebYYPCU
Your timeline is out of order for that process.
The Sketch to edit was created before the problem body was imported.
Create a new Sketch at the end of the timeline and project the problem sketch articles forward.
Might help.....
TheCADWhisperer
Try this one.
Does it work now?
Also - you will probably want to add Fillets to these inside sharp corners.
nor500
It solved the problem. Thank you! You are awesome! Also I will add some filets to inside as well.
TrippyLighting
If any of the answers above solved the problem, then please accept those posts as the solution, by clicking on the large, hard to miss "Accept Solution" button 😉
