Odd issue with sketch demensions.
littlebill2121
littlebill2121
I am learning to use user parameters more, to scale or make changes quicker. Found a interesting bug? not sure if its me or what the issue is.
but the sketch demension jumps to a different part of a circle after changing a size parameter, it only does it on one side of a rectangle. am I doing something wrong? or is this another issue?
all i am changing is the circle diameter from 15 to 25mm its only after going past 25 or so that it flips, 16-17 etc they work fine...
g-andresen
What about the width of the rectangle?
günther
littlebill2121
Not sure I know what that means? shouldn't it just grow as needed to meet the constraint? which it does, even if i scale up largely it just constrains to the wrong side of the circle
littlebill2121
starting to think this is a bug. if i slow increment it, like 1 or 2mm at a time, it works fine. if i try to jump it up like 20 mm at a time, this is what happens?
g-andresen
Your pattern has no relation to the width of the body.
günther
jeff_strater
yes, @littlebill2121 , you are correct - this is a bug.  Thank you for sharing the design, it will help us track this down.  Created FUS-92911 to track this issue.
Jeff Strater
Engineering Director
littlebill2121
Thanks Jeff. Seemed weird to me.
